GFX cooling - Something small
Permabanned
15 Nov 2011
I need to replace the stock cooler on my GFX
It's ether a 770GTX or 650 TI. I've both but unsure yet.
Case is small, Lian LI TU-1000 so I've only 190mm
What's a good after market air cooler to fit
I think you should probably determine which it is as there is a large difference in wattage to dissipate between those two cards.
650Ti - 110W
770GTX - 230W
The 770GTX would require one of the top end solutions such as the Arctic Accelero Extreme, Alpenfoehn Peter or the Prolimatech MK-26, while the 650TI could probably manage with a single fan or dual fanned Arctic version such as the L2 or the Twin turbo.
