I've recently been having problems with my 7600GT where after a period in game (mainly Oblivion and HL2) the red vanishes from the palette. Usually if I exit the game, the colour returns, although sometimes this takes a few minutes.
I've since installed nTune and run the stability test, and the temperature normally is about 55 (GPU1) in Windows which seems a little high. During the stability test it gets up to around 65-70 and during this the loss of red seems to kick in. Stop the stability test and once the temperature dips below about 57/58 the red returns again.
Couple of questions: -
1. Is this running very hot? I know my airflow is not particularly good (and I had planned to improve it) but what sort of temp should I be monitoring?
2. Has anyone else had this sort of issue with loss of a primary colour, particularly as a consequence of overheating?
3. What's the best solution, fan-wise? I've got a cheapo case, and the only extra grill is at the back halfway down? Should I be sucking or blowing (oo-er)?
EDIT: I forgot to say, it's with the stock cooler. How easy is it to replace?
