GG or HH pads
  • Thread starter Thread starter Ish
  • Start date Start date
Ish
Ish
11 Jan 2006
West Midlands
Hi
My Thundercat needs brake pads and it currently had GG pads in. Will I see any benefit going for HH pads considering the bike is used for 80% commuting?
I doubt you'd notice, I go with HH generally because I quite like to slam the anchors on up to a corner, but the GG I have in now have been just as good for my skill set, track use on the other hand...
HH tend to last longer and have better bite,im using cheap goldfren pads atm,seem fine
always used ebc hh pads but they have got expensive now for some reason
