I just got my hands on an Opteron/X2 heatpipe cooler off a fellow forum member, when I received it I had the feeling it would not fit, because I was not aware it was the newer revised version by AMD.
And in fact it took hell of a time and efforts for me to find the ONLY position that it would be mounted right, the base and fins area are huge I don't even have space to mount my beloved OCZ ramsinks on the ram chips. And guess what only zip ties/cable ties work, not even a slightest way to use screws.
Well, that's the only downside, the cooler works like a beast lol, and I'm happy with my purchase. For reference, stock X1950XT cooler kept temp at 81C under full load (mounting is fine with AS5, it's just a very hot card). The Opty cooler now does it at 60C !!! (a whopping 20C lower lol, and what's more, it's extremely silent albeit sporting a 70mm fan spinning at 3000rpm)
Some piccies
Fitted
Mounted
My friend with the 1st version of the cooler on an X1800XT inspired me. He got to use ramsinks as well, which in my case I can't.
Last but not least, TEMP !
Some piccies
Fitted
Mounted
, in the pic it looks emphasized, in fact it's just a little bit beyond bending point since I could not use the 4 inner holes due to the base of the heatsink being too large, and when you use the outer holes then tighten the ties, the card is bound to get bent towards the center, but nowhere near braking lol
