Ghost Net connection disables internet
10 Mar 2012
unstated.assortment.union
Hi,
Since a recent windows update when I switch my PC on in a morning I have no internet connection. Pc connects to the router fine as I can still access the router control panel but Windows will not go any further.
Network and sharing show 'No internet connection' and 2 network connections:
Home Network (as it should) and Unknown Network
Both say that the access type is Internet, Joined and using local area connection (cabled)
Now if I disable my network adaptor then re-enable it, the unknown network disappears, leaving just the home one and my internet access is restored.
This issue has only occurred in the last few days since recent windows update.
I'm using Win7 Pro (SP1), all drivers have been checked and updated.
I'm fairly new to Win7.
Does anyone know what's going on?
Yes. Everything else is as it should be other than this 'ghost' connection seemingly not allowing any software to use it. Disable/enable the network adaptor and the ghost connection disappears and normal internet connectivity is restored.
----Edit----
Also forgot to mention, if I click Connect/Disconnect Network nothing happens and I cannot disconnect from either unless I disable the adaptor.
Do you have any VM applications or perhaps something like logmein/hamachi installed> Could you grab a screen shot of the network connections page and device manager with the network hardware tab open (right click computer > Manage > Device Manager)?
Like this
Here you see I have an unidentified network - it's the virtual network connection for VirtualBox and is currently not connected
I used the Microsoft Snipping Tool to grab those, type snipping into the Start/Search box
I haven't installed any VM software, unless any comes with a Win7 install which was a full and clean install 6 days ago.
Screen shot in previous post is from when I cannot connect
This one is from after I've disabled and enabled the adaptor:
And this is device manager:
Does that give any clues?
Nope, sorry :( I was shooting for the virtual adaptor off-chance :(
Edit: Purge your system of any antivirus software you currently have, see if there is any change in behaviour
