martin9887 said:Hi All,
Got this today but im having graphical problems, I have 8800GTX currently using 163.11 on Vista 64 Bit,
That's basically all I get, I tried in training mission but was the same.
Any ideas? Thanks.
try this
First you need to check in your Nvidia Control panel (Make sure your in Classic View or you wont see it) for an option to called "Frames to render ahead" and default is 3. Change it to zero and its fixed.
If you dont have the option you need to get "Coolbits 2.0" and install it. You then will have the option plus some you prolly have never seen there and also the ability to OC your video card. (Dont do that unless you know what your doing). Make sure you have the latest Nvidia Forceware before you do this.
worst fps ive played in a long time.
