Ghosting Check
9 Jul 2005
High Wycombe
Is there any software that I can use to check if my monitor is up to the job. Am taking my lcd logik TV to put on my computer and need to see if its good enough.
Its 27inch but cant fing any details on the panel response time - have tried in BF2 but I am not that great at seeing it - is there anything which will make it obvious?
Its a Logik lcx27wn2 if anyone has one
I'm a bit confused there. You say you've tried it in BF2 and can't see any ghosting or issues? What are you trying to find if it's up for then? my advice would be not to bother going looking for it, there's no point really. If it performs fine to your eyes, in your uses, then dont worry about it :)
I'll be honest - I dont know what I am looking for - there does seem a bit of lag on the screen - if i move the mouse quick then the buildings seem to stay a bit behind the view but not sure if thats the graphics card or the screen - the image is crisp so not blurred which I thought ghosting was.
Is there any other way to check/test?
not really. Ghosting and blurring is very much down to perception. I'd again suggest not bothering to go searching for it. If it meets your requirements, why bother, it will only annoy you in the future :
