Ghosting effect!!
13 Feb 2009
London
Not really sure what this problem is, but as it's showing on the monitors, i thought i see if i can get help here ;)
Ok in bf3, bf4, When turning with my mouse left, right up and down, i get this ghosting effect. if i'm flying in a jet, heli, i don't get this at all, it's very smooth.. i didn't know what this was called untill i researched it.
I found A youtube clip (which isn't mine of course) which shows the same problem i'm having!!
The 2 monitors i tried, are Hannspree HF-289HJB, and the Acer X223HQ.
What causes this? and how can i fix it!
My spec!
Win 8.1 64bit
Phanteks PH-TC14PE CPU Cooler
i5-3570K -- i7-3770K to be installed!
Crucial RealSSD M4 256GB X 2 Raid0
GA-Z77X-UD5H (rev. 1.0)
Kingston HyperX Genesis 16.0 GB
2 x Gigabyte ATI Radeon HD 7970 Windforce 3X. soon to be Sapphire Radeon R9 290 Tri-X
Seasonic 860w '80 Plus Platinum' Modular Power Supply
Cheers :)
If you look at the moon at the bottom! this is what i get!
http://frames-per-second.appspot.com/
I think it's probably the game doing it. Usually frame "smoothing" does stuff like that because it puts in extra frames. Looks terrible, I don't know why devs bother with it.
I had that king of effect happening in BF4 with my new monitor, i played around and for me turning Vsync on fixed the problem and now its a lot smoother.
May not be your issue but just something i had.
You sure it wasn't tearing ?
Only happens with v.sync on.
I just changed the 7970's (which i'm selling) to a single 290! and still the same, but not as bad as when i had crossfire!! don't think i ever go back to crossfire, unless i find the right monitor.
I get a kind of lag with the mouse with v.sync on! but far to much tearing with it off!! not sure how some don't get tearing when going over there refresh rate!
Drives me crazy, as i can't aim very well lol.
