6 Apr 2006 at 19:58 #1 Morlan Morlan Soldato Joined 18 Oct 2002 Posts 3,245 Location melbourne I'm currently using a 40GB drive for C: and I want to ghost it to a new 80GB drive using Acronis TrueImage. Will Windows throw a fit when it discovers that the drive has changed model/size?
6 Apr 2006 at 21:14 #2 Hussman Hussman Associate Joined 1 Nov 2003 Posts 1,271 Location Maidstone, Kent No, you will be fine. Windows will detect a new HDD, but it won't affect the process. It's worked for me.
6 Apr 2006 at 21:22 #3 Morlan Morlan Soldato OP Joined 18 Oct 2002 Posts 3,245 Location melbourne Many thanks mate. Got it sorted.
7 Apr 2006 at 12:20 #4 Dutch Guy Dutch Guy Soldato Joined 18 Oct 2002 Posts 24,560 Location Amsterdam,The Netherlands Morlan said: Many thanks mate. Got it sorted. Click to expand... I will do this as well when I get my new harddisks, can you tell me if it went withouot a hitch? Did you disconnect the old drive after ghosting and booted with the new drive straight away without problems?
7 Apr 2006 at 14:28 #5 wesley wesley Soldato Joined 29 Jul 2003 Posts 7,701 what i did : oldie 80GB sata hard drive C: (winXP) as SATA0 need better hard drive so got myself a nice 74GB Raptor plug it in SATA1 boot up Acronis TrueImage, clone the drive to new Raptor shut down disconnected oldie 80GB sata hard drive disconnected Raptor drive from SATA1 then plugged in SATA0. boot up and its done if you're using IDE drives, just change the jumper setting on the IDE drives
7 Apr 2006 at 14:51 #6 Dutch Guy Dutch Guy Soldato Joined 18 Oct 2002 Posts 24,560 Location Amsterdam,The Netherlands Sounds easy enough, I just hope my ghosting goes as smooth as that as I will be going from IDE to RAID-0 SATA drives.
7 Apr 2006 at 15:08 #7 Rambaud Rambaud Associate Joined 15 Apr 2003 Posts 1,877 Location Hertfordshire I do mine from within Windows - although Acronis still has to use DOS for the actual cloning.
7 Apr 2006 at 18:21 #8 Morlan Morlan Soldato OP Joined 18 Oct 2002 Posts 3,245 Location melbourne It was very easy wiuth TrueImage. Plug in the new drive as slave Run the TrueImage wizard Reboot Once it's complete, remove the old C: drive and set your new drive as master Done!
