7 Dec 2006 at 20:02 #1 Mr Mag00 Mr Mag00 Associate Joined 23 Mar 2006 Posts 960 my monitor has just started ghosting, a slight double vision. its an acer al1916w, is it the monitor or gfx card? i have rebooted to no effect and turned off the monitor too, any ideas welcome. TIA
7 Dec 2006 at 22:16 #2 Baddass Baddass Man of Honour Joined 12 Jan 2003 Posts 20,741 Location UK try it on another machine, prob best way to be sure. check cabling, make sure you're running at 60Hz refresh rate.
8 Dec 2006 at 19:41 #3 Mr Mag00 Mr Mag00 Associate OP Joined 23 Mar 2006 Posts 960 ok will do, away from machine for a while but will try that when i get back thanks
