This should not be the case am I right?
I think so, if you believe the hype this card should be pumping out the fps like nobodys bizz
heres my setup
MOBO: Asus Maximus 7 Ranger
RAM: Corsair Vengance Pro 8Gb 1866MHz
GPU: Gigabyte G1 GTX 970 4Gb
CPU: i4790k watercooled with a H105
PSU: cooler master v700
Running on 1080p full hd monitor
Nothing has been tweaked or OC'd (although I'll get to it at christmas when I'm off college), however I'd expect mostly 60 fps on frarcry 4 with this rig however its basically staying on 30 fps and going up 60 fps for a bit (actually its behaving like its capped at 60fps which I'm thinking maybe one source of the issue but I dont know to switch it off), very frustrating. I've watch a couple of vids of other setups with this card and theirs is basically anywhere from 50 to 80!!!
So I'm looking some advice, where do i go from here? Surely its not a faulty card, I'm think my system isnt optimally set. Where do I start? What things should I be looking for to diagnose the issue? Can you link to any good pages which will have good info on anything related?
Thanks for reading folks, all reply's welcomed and appreciated
heres my setup
also farcry 4 is now the beautiful game i was expecting it to be so double thumbs up
