GIF with sound?
22 Oct 2005
Moving...
I'm after a piece of software that will basically let me make a gif with sound. Not sure what the most widely used format for this would be, I guess some form of flash aniamtion would do the trick.
I've got 2 images, and a sound clip about 10 seconds long. Depending at what point we're at in the track, I need to display either image 1 or 2.
I've got adobe flash cs3 but have never had time to use it. I fired it up last night at work but wasn't able to figure it out.
Is this something that's quick and easy to do in flash or is there a more simplistic application that's do the trick. Obviously I'd like to work out how to use flash properly but this needs to be done by tomorrow :/
Thanks for any advice.
