- 14 Feb 2003
- UK
I have a Realtek based Gigabit network PCI NIC in my PC (WinXP). I have this connected through a Netgear 5 port switch to a Synology NAS with a gigabit chip in it.
Problem: each time I boot-up the PC the link between the PC and NAS seems to reset itself to 10/100 mode. Going into Network connections and getting it to renegotiate the connection will set it correctly back to gigabit speeds.
I notice also that if the PC is already booted into Windows, if I turn the switch off then on again the connection will return to gigabit speed.
The Netgear switch shows an orange light for each 10/100 port connection and green for a gigabit connection. I notice that when I first switch on the PC the appropriate port on the Netgear switch is orange. Only once Windows XP has booted up does it change from orange to green.
It seems that the NIC BIOS is initially reporting itself to the switch as a 10/100 card and that is enough to confuse the switch into setting the wrong speed. Only once the Windows driver is loaded will it show itself up as gigabit.
Any clues how this can be fixed? There are lots of driver settings - any idea if one of these can be changed so that the BIOS reports the NIC correctly?
Not a big deal, but it is a pain to have to reboot the Netgear switch every time I turn on my PC.
Thanks for any help.
