GigaBit Connection question
18 Feb 2006
Halifax
Hi All
Just a quick question though I am not sure of the answer I have a Synology NAS 107+ and I would like to stream video and audio from the NAS to 2 PC I have in my house. Now both of the PC have GigaBit network ports on the rear.
My main pc is using Asus P5N32-E SLI motherboard it has 2 Gigabit ports on the rear, my Netgear 834N router is connected to one and the other is empty.
I also have a media centre PC that I would like to stream data from the synology with a D-Link Network card fitted also Gigabit
The Synology 107+ has a Gigabit port on the rear
At the moment both of my PC and the Synology 107+ are connected to the router using network cables
Now the router is a bottle neck
Could I buy a Gigabit swith and connect this to the Netgear Router then connect my Synology 107+ and my 2 PC to the switch,
Would the Synology download station still work with the download station turned on, pc still connect to the internet ect..
I have just read the above at it looks confusing I hope you can understand what I'm trying to do
I am looking at buying
http://www.overclockers.co.uk/showproduct.php?prodid=NW-100-NG&tool=3
Many thanks for taking the time to reply
Exib
Quick answer - Yes.
Connect everything gigabit to your switch, then run 1 cable from your switch to your router (100mb) and everything should transfer through the switch unless it is gateway traffic :)
