- 14 Dec 2005
- Bath
Simple question really, what's a good Gigabit N-Router?
The current set-up is a Netgear DG834GT ADSL Router (with a Hi-Gain Arial), with desktop PC connected to it, and a Netgear gigabit switch plugged in aswell upstairs (with desktop PC's on that.)
Connected wirelessly are my MacBook Pro and dad's Dell, both of which have 802.11N (but are currently using 802.11g). Occasionally connected are other 802.11g laptops/PSP's etc..and there is also a desktop PC with a Netgear WG311T (but that hasn't been turned on for over a year!)
The desktop PC's have gigabit ethernet, but are being limited to 100mbps by the router, and the laptops have 802.11n but are being limited to 54mbps by the router too..
I've found the Netgear WNR854T, but that doesnt have a built in ADSL modem. There's the Netgear DM111P modem, but I've read loads of bad reviews on it!
Would it be possible to use the existing DG834GT as just a modem? (connect it via ethernet to the WNR854T router)?
Is there a more trustworthy modem then the DM111P out there? Or are the reviews I've read lies/relevant to old firmware?
Or is there a Gigabit N ADSL Router I've missed?
TY All......
TY All......
