Having just invested in a Synology DS209 and a new PC, I wanted to get the two talking to each other at Gigabit speeds.
I bought a Netgear GS605 switch and connected to this are now:
- Router (Linksys) with 10/100 ports;
- PC (with a Gigabyte motherboard - on board networking via Realtek Gbe Controller)
- DS209
The DS209 connects to the switch at Gigabit speed without fail, every time (green light on the switch to confirm). I can't get the PC to connect at this speed though. It maxes out at 100Mbit but often drops to 10Mbit.
I run both Windows and Linux and both have the same problem. I've tried disabling auto-negotiate to force 1000Mbit but that doesn't work, I swapped cables with the DS209 but that doesn't change things either (the DS209 connects at 1000Mbit with either cable).
After a bit of Googling, it looks like it may be either:
- a compatibility issue between the Realtek and the Netgear
- the GS605 is generally a **** switch
Does anyone have any suggestions as to what to try next? I think my options are:
- buy a PCI Network card (but most seem to use Realtek controllers? so may still be a compatibility issue)
- get a decent switch (any recommendations?)
Thanks.
- DS209
Thanks.
