Hi Ive just fitted my house out with Cat 6 cabling but im a little stuck on what gigabit switch to use. The switch will be fitted next to my adsl2 router and my plan was to connect the switch to my router to supply bband to all points on the network. I originally planned to use the Dlink GDS-1008D(need 7 ports) because of the low power consumption and ability to wall mount it. After reading up a bit though it seems jumbo frame support is really useful on a cat 6 network to reduce overheads which the Dlink doesnt support.
Another item ive read said that if your using the network for internet as well jumbo frame support will cause problems with pages loading, something to do with the larger frame sizes causing pages or requests to time out. Im now confused and dont really want to make the wrong descision without getting some other opinions.
What do you guys think? and any other switches i should consider as well as the Netgear GS108, i have about £50-60 for one.
