- 20 Apr 2008
- West Midlands
If I'm upgrading to 100mb virgin will a 10/100 (dir-815) router serve me well or do I need a router with gigabit ports?
As long as the router supports speeds of 100mb/s on the WAN interface you should be fine. You will not see a benefit from a gigabit router in terms of internet speed. If you do change to gigabit and connected devices are also capable of gigabit then you will see an increase in streaming media and copying files between devices. I hope that makes sense?
Actually, this is incorrect.
With overheads for Ethernet and actual payload from the WAN connection, you'll be needed gigabit to get the last wee bit of bandwidth.
Plus... IIRC, the d-link only has an actual throughput of 55-60Mbit?
Just checked, according to the device webpage, the WAN port is also 10/100, so it *should* handle this fine.
