Hi all,
I've got a Gigabyte 3070 Gaming OC today - second hand. I read on reviews that the card runs at 68-70C under gaming load. Well mine doesn't! It skyrockets to 79-80, fans run at 100% and it throttle itself because of temperature. This is with the "OC" BIOS but I read that the difference is just a couple of degrees with the Quiet bios.
After undervolting, the situation is much better, I get 75C maximum. I'll open it up and replace thermal paste but I'd be surprised the paste degraded so much as this is a 3YO card. Can someone confirm that this should be a relatively cold/quiet card?
I hope it's the paste, when fans were running at full speed (they were loud!) the air coming out of the heatsink didn't feel particularly hot, hopefully showing a lack of heat transfer from the GPU IC.
Thanks!
www.techpowerup.com
Thanks!
Gigabyte GeForce RTX 3070 Gaming OC Review
Gigabyte's GeForce RTX 3070 Gaming OC is a factory-overclocked custom-design variant of the GeForce RTX 3070. It comes with a large power limit increase, and temperatures are still much better than with the NVIDIA RTX 3070 Founders Edition.
