I had this case as well and found it pretty good. I think the GTX will fit with a squeeze, but the big minus on this case was the way airflow from the front fan was restricted by the hard drive bay layout. Also, if you get the one with the vented sidepanel some people have reported their temps going up as it interferes with the front fan in / rear fan out airflow stream. I would get an Eclipse or Mirage and add the thermal sidepanel if you need it. Or a Lian Li PC7 - as the front fan is very unrestricted and the case cools very well. Just won't fit a gtx over the hd bay.
