Gigabyte 3d aurora
Caporegime
20 May 2007
Surrey
I really like the look of these, any of you had any experience with them or know whether they are any good?
I’ve got one and i think its a good quality case. It has a decent amount of room inside and I find the screw less design useful when moving HDDs and DVD drives. I’ve got watercooling installed, and with its pre-drilled holes it very simple to install, i.e. no modding required.
Vie got the be honest though, the airflow into the case isn’t the best which is disappointing for the price.
Overall I love it.
Overall I love it.
Hm, good to hear, i really think they look great, im gonna go for the slightly newer 570 version to accomodate the 8800gtx and give me a bit more room.
Yes, I don't know the advantages of the newer version over the old one, but I liked the looks of the older one, thats why I bought it over the newer one. I know that both cases can fit the 8800GTX.
The only problem I have with these cases is that the HDD cage blocks the air intake at the front of the case.
Can you remove the HDD cage from the front of the case to improve airflow.
