Gigabyte 5700xt
16 Oct 2013
Hi guys after a bit of advice I have the gigabyte 5700xt that constantly driver times out or crashes this is very annoying it has 3 year warranty I've tried every fix on the net everything running stock still crashes
My question is can I rma for this and is there any point as there no gpu out there anyway I do t really want to be without a card for a month I am just weighing up my options
Thanks
Sometimes a bad install can cause issues so try using DDU to completely remove the driver and reinstall it again. Also if you are overclocking the gpu or cpu then set them at stock to rule out bad overclocking.
Maybe another part of your system is causing the crashes so it is worth trying the 5700XT in another system if you have access to one to verify if the gpu is the actual problem.
If your using the latest drivers that's probably the issue i had it with a 5600xt constant driver timeout errors roll back the drivers to late 2020 stopped it for me
