Hello, I recently upgraded from a GTX280 to a Gigabyte 660ti.
The Gigabyte has two large quiet(ish) fans, I have found a way to change the fan speed curve with MSI afterburner but I can’t get it to run slower than 40% at idle, even if I select 30%
Is the minimum fan speed perhaps a BIOS setting that I can’t change with software or is there a program that I can use?
If it is a BIOS setting is it a case of waiting for a BIOS update that allows lower than 40%
