Hello, I bought this card not too long ago and randomly a rattling noise on the gpu occurs. For example, I played Guild Wars 2 this morning, after about 20 mins a rattling noise can be heard from the gpu, I alt tabbed then increased the fan speed manually, it got a little louder but then stopped, re-enabled auto fan and the rattling is gone.
I can't get it to do it on its own, even setting it to the same fan speed it was rattling at, running 3dmark twice or other tests using the gpu. The gpu is seated properly, checked fans and even tried checking the fan screws but they were tight already.
I can't send it back for dsr and since I can't reproduce it wouldn't they just send it back?. Did it a few times in Tomb raider. Not sure what to do, any advice please?, Thanks.
