- 26 Sep 2005
- Tonbridge, Kent
Hi,
Recently upgraded to Haswell - bought a 1150 mobo and cpu
The mobo is a Gigabyte Z87m-D3H
The build was going fine until I installed my MSI HD 6850 1024MB GDDR5 PCI-Express Graphics Card.
The motherboard simply doesn't detect it. It's sitting in the PCE-E 16x slot with a Xonar D2X in the 4x
I've been researching and it seems a lot of people had a similar issue with the Z77
http://forums.overclockers.co.uk/showthread.php?t=18492809 <- btw I don't have a dual bios, just the vanilla card.
The on-board graphics is the only way I get the monitor to come on. The gpu is definitely working, fans are spinning, the PCIE power connector is on and the card is sitting correctly.
I'm going to attempt to flash the bios.
Anyone got any other ideas?
EDIT: I've flashed the bios to F7b (beta). Tried changed the PCI-Lan to different gens 1/2/3
Regards,
Ben
Regards,
Ben
