- 21 Apr 2007
Hi guys, got a hold of a new card and basically instead of two 6pin power connectors it has 1 8pin and 1 6pin connector.
The manual shows you can just connect two 6 pin connectors to the card but I'm not sure if it's just a bad illustration and you actually need to have an 8 pin connector?
Can anyone please clarify.
My PSU also only has 2 6 pin outputs no 8pin outputs so would I need some kind of adapter or can I just plug it in?
