Hi,
Anyone else have problems with their Gigabyte 8IPE775-G fan control?
Whenever the CPU reaches around 40C the fan goes up and down up and down, which is super turbo annoying, it doesn't go slow, bit faster, faster, faster, fastest etc etc like most other motherboards do.
I have it set to PWM mode, voltage is just as rubbish, and if I turn the fan control off it makes the PC noisier & if the PC gets around 50c the fan just spins faster and faster and doesn't go back down...
Anyone else had & sorted these problems? Is there any way I can sort this problem please?
[Edit]
I've found BIOS updates for it, maybe that would help?
If it would then which one would I get?
This: http://www.giga-byte.com/Motherboard/Support/BIOS/BIOS_GA-8IPE775-G (Rev 1.0-1.1).htm
or this?: http://www.giga-byte.com/Motherboard/Support/BIOS/BIOS_GA-8IPE775-G (Rev 1.2).htm
(Rev 1.0-1.1 or rev 2.0?)
Here's my current:
Also, wasn't sure if this should go in motherboards or cooling. Sorry if it's wrong.
Thanks
Craig.
[Edit]
Here's my current:
Thanks
Craig.
