Gigabyte 8IPE775-G Revision
2 May 2004
Hi,
I have the Gigabyte 8IPE775-G motherboard and need to find the revision as I want to upgrade the BIOS because the current fan control is SUPER annoying, the new BIOS has better, more custom fan control (can tell the PC what temps to increase fan speed etc).
Anyway, there's revision 1.0-1.1 and revision 1.2 for my motherboard & I need to find what revision it is so I can upgrade.
Any ideas where I can find the revision number? I have checked all over the board and can't find it :(
Also, I am currently on F3 on this board (stock) and there's a F6 out, is it alright if I update straight to that?
Thanks
Craig.
