Permabanned
- 31 Jan 2009
- Somerset
Hey i just installed my Gigabyte 970A-UD3P and a fx 8320 and some new ram it all started fine working perfecty i was happy
Then i went to restart my pc but ended up doing shut down instead so i returned on the pc the fans started but no beep and the monitor just kept flicking on and off
i looked inside and it seems the led on the motherboard wasnt on so i turned it all off unpluged it and retried it worked ok again then i thought i will turn pc off and return it on to see if its better now
but nope same issue it seems sometimes my motherboard works sometimes it doesnt i tried resetting the bios that didnt help i unplugged the cables inside the case and that didnt work im not really sure whats wrong with it
please help GothicCorpse
