Gigabyte A320m-S2H wont start with external gpu
17 Jun 2004
Eastbourne , East Sussex.
Board is running with a AMD 2200G and the F50 bios, it works fine with the igpu - however it doesnt run when a GTX 1060 is plugged in to teh pcie slot.
The gpu fans spin but no video out put at all.
The GPU works in any other machine.
ideas?
ideas?
Might have to turn off iGPU in bios .
Orbit think display should be plugged into mobo hdmi/DVI which again you'll have to change
Do you let it go all the way to Windows boot? I have an odd issue with my Zotac 1070ti and Asus X570-P where it will show no output until Windows actually loads 9/10 times. Once in a blue moon it will display POST and i can get into BIOS. However with an ancient AMD 6570 i have knocking around for testing it shows POST 100% of the time.
