Gigabyte Aero 15 and 14
12 Oct 2017
London
So basicly I need to compare display response time and battery life (web surfing).
https://www.notebookcheck.net/Gigabyte-Aero-14-7700HQ-GTX-1060-Laptop-Review.211666.0.html
https://www.notebookcheck.net/Gigabyte-Aero-15-7700HQ-GTX-1060-FHD-Laptop-Review.215364.0.html
Specs according to notebookcheck
Aero 14 :
Display (LP14QH1-SPF1) - 25 ms, 257nits, 92 sRGB
Battery 15h (idle) and 8h 44m (wifi)
Power consumption 8 - 20 w (idle) and 78 - 146 w (load)
Noise 30 - 53 db
For Honor 42 fps​
Aero 15:
Display (N156HCA-EA1) - 32 ms, 316nits, 92sRGB
Battery 10h 38min(idle) and 7h (wifi).
Lower res. display, newer laptop, same specs (power consumption little higher) results in 2h (web surfing) and 5h (idle) decrease?
Power consumption 12 - 20 w (idle) and 82 - 161 w (load)
Noise 32 db - 50 db
For Honor 70 fps (+30 fps o_O)
Easy Aero 14 win right? - No
Lets compare display's on different web
Aero 14 http://www.panelook.com/modeldetail.php?id=31862 - 35 ms, 700:1
Aero 15 http://www.panelook.com/modeldetail.php?id=28005 - 14 ms, 700:1
Battery life on other sources is different some get on 15 - 8h and 14 - 5h (same source) right the opposite to the notebookcheck. I don't say about other sources (including youtube) 5 - 9 hours (both 15 and 14 via web surfing test)
Comparisons:
https://noteb.com/?model/comp.php?conf0=14050364697873999872&conf1=11034663433738000384&ex=USD
Aero 15 reviews:
https://www.techspot.com/review/1399-gigabyte-aero-15/
http://www.expertreviews.co.uk/giga...iew-where-elegance-meets-high-end-performance
http://www.computershopper.com/laptops/reviews/gigabyte-aero-15
https://www.bit-tech.net/reviews/tech/laptops/gigabyte-aero-15-review/1/
https://www.pcworld.com/article/320...review-a-near-perfect-power-users-laptop.html
http://www.techradar.com/reviews/gigabyte-aero-15
http://www.trustedreviews.com/reviews/gigabyte-aero-15
https://www.laptopmag.com/reviews/laptops/gigabyte-aero-15
https://www.pcgamesn.com/gigabyte/aero-15-review-performance
Aero 14 reviews:
http://www.computershopper.com/laptops/reviews/gigabyte-aero-14
http://hexus.net/tech/reviews/laptop/102115-gigabyte-aero-14w-v7/
http://www.techradar.com/reviews/pc...-and-netbooks/gigabyte-aero-14-1322622/review
https://unlocked.newegg.com/reviews/review-gigabyte-aero-14-gtx-1060-laptop
QUESTION
I need to know response time and battery life (web surfing) for these laptops from other sources (not notebookcheck). Any info about 14 and 15 are welcome. Any shops with Aero 15 and 14 in London? Feel free to recommend laptop with possibility to disable dGPU for longer battery life (could be BIOS, optimus etc.), ~25ms, >90whr and 1050Ti / 1060 on board. Thank you for your time.
I really, really wouldn't stress about numbers. You'll only end up disappointed, as windows has poor battery life regardless. Any screen response time will be more than good enough on both displays.
Speaking from experience
