- 2 Feb 2008
- Rainham - Kent
Anyone got this monitor?? whats's it like??
I just got mine delivered yesterday, so far I'm very pleased with it. I replaced my middle Dell U2715h in a 3 monitor setup and it fits in well.
So far I've tried a little gaming and it was a noticeable difference over the old 60Hz screen (even moving windows about the screen is smoother).
I've also spent an hour or so doing some software development and everything looked good on the screen - just pointing that out as this panel is BGR rather than RGB (which people had pointed out this can cause some text rendering issues), so my main worry was if it would be a problem using it for looking at text for long periods of time, so far it seems good (though you will probably need to turn down the out of the box brightness)
Note: For the text clarity, you will need to run the Windows Cleartype setup, which will take you around 30 seconds.
I'm not sure what to make of the OSD Sidekick software, the settings it shows don't line up with what it says if I actually bring up the OSD on the monitor.. right now the monitor itself says that brightness is 65, while the Sidekick software says it is at 45.
