Gigabyte AORUS ELITE B850 - aio install help
19 Oct 2011
Hi
Hoping someone can help in regards to which headers to plug the aio cables into.
My aio is the lian li galahad 2 360 performance lite. Motherboard is gigabyte AORUS ELITE WIFI7
There's 3 cables:
1 cable coming from the fans
2 coming from the pump block - one for the pump and one for rgb.
For the actual radiator fans, my case has a fan hub so I'm pretty sure I can plug this in here? The fan hub connects via 1 cable to sys-fan1 currently.
The rbg header is fine.
I just don't know where to connect the pump cable to, watched tonnes of reviews, reddit and even chat gpt/Claude giving me conflicting advice!
The options are:
CPU-OPT
CPU-FAN
and less popular FAN4-PUMP
Please someone advise on where these final cables go!!
Case if Asus proart pa602, no additional fans installed, the 3 pre installed all coming from the fan hub currently.
Thank you!!
Adam
Fan to CPU-FAN
Pump to FAN4-Pump
RGB depends on what type you have, be careful there as plugging the RGB into the wrong header can actually damage them. Your case may have an RGB hub built in that could be used also, but you'll need to double check that.
See here: https://www.reddit.com/r/buildapc/comments/ku117m/a_beginners_guide_to_rgb_in_2021/
Thanks.
Case doesn't have an RGB hub, just a fan hub.
Could you explain why the radiator fans goto Cpu fan and not the fan hub?
And why the pump goes to FAN4-Pump and not the others?
If you don't mind, just for my own sanity as I've read so many differering answers!
Thanks.
The CPU-FAN header allows the motherboard bios to easily alter fan speeds on the fly while monitoring CPU temperatures, helps keep things as cool and quiet as possible.
Depending on how aggressive the default settings are, you may want to play about in the bios to set a fan curve.
Pump headers should supply more power than other fan headers from what I remember, which might be necessary for the pump to run optimally.
Thanks.
the fan header that is called "cpu fan" is usually the one thats attached to the cpu cooler
the cpu cooler is usually either a air cooled tower with a fan[or fans]
or its a radiator with..... yep fans
so it is in fact the cpu cooler so the fans on your radiator are the same as the ones on my aircooling tower as far as the job they do
which is get airflow through the cooling medium whether thas a radiator or a heatsink on a tower air cooler
its the effective equivelant thing
it is the cpu fan so to speak in this scenario
so thats why in general and i mean that as in usual practice this would be connected to cpu fan
thats the normal convention as far as i understand it lol
Slight problem.. The cable is really struggling to reach FAN4_PUMP, with the Gpu installed it will be touch and go.
The manual for the mobo gives an almost identical description for FAN4_PUMP and CPU_OPT.
CPU_OPT actually says (CPU Fan/Water cooling pump header)
FAN4_PUMP (system fan/water cooling pump header)
Not sure if you got this sorted but you don't plug the AIO into the bottom pump header, it is intended for CPU_OPT with the fans from the radiator on the CPU fan header.
You still get to control the pump in bios, think my lad ran his at 70% for an inaudible pump, with a ramp up to 100% when the CPU gets really hot.
Gigabyte Aorus B850 with a 9900x and Be quiet! Silent Loop 3
I'm sure it is also in the online manual? Or even some reviews or YouTube builds.
The bottom pump header is great if you have a custom water loop with a stand alone pump and reservoir.
Yeah that's all right.
I have older aorus board
CPU FAN - Radiator Fans
CPU OPT - Pump
Fan/PUMP - Pump
* on my board:
D_LED1/D_LED2 - RGB 5A
LED_C1/LED_C2 - RGB 2A
