Hi all,
I bought and installed a Gigabyte Aorus F127q
https://www.overclockers.co.uk/giga...ync-led-backlit-gaming-monitor-mo-004-gi.html
However, whenever I run above 120hz I get a high pitched noise similar to the noise you'd hear if you have tinnitus.
I've done some trouble shooting online and followed the standard; check sound, check cables, check power, configure colours/brightness but nothing removing or even reducing the noise.
just quickly my set up is:
Palit 2080ti oc
2x8gb 3000mhz kingston
b450 Aorus mobo
3700x
I never post on forums, so apologies if I've missed a level of standard - but hopefully someone out there has some knowledge that could help
Palit 2080ti oc
b450 Aorus mobo
3700x
