Gigabyte Aorus X570 Master constant noise level
8 Jan 2020
Bios version F11. In the Aorus SIV application on the Smart Fan 5 Advanced tab, my noise level is constantly at 88dB even when the Smart Fan5 Auto is set to Quiet mode. Any one else seeing this? I have checked the connection of the noise sensor and it can only be connected the one way.
Got the ultra
Board just below yours
But it's pretty much the same bar power delivery
And slower ethernet
No problem here
But about 30 minutes ago it said there's a bios update
I am on f11
Not had time to look yet
But may be of help possibly
And what are the fans actually doing?
Quiet
Loud
Totally opposite of software report etc
Ie fans/noise is fine it's just software is wrong
edit
and still says f11 on website
but firmware update utility is updating it to i dont know what
as i type this
weirdly it flashed f3 on there
trying to go back to f11 now
The fans are running very quiet and still reads 88db. If I keep the SIV software open on Smart Fan 5 Advanced I see constant 88dB. Leave SIV open and run the HWINFO application and select Sensors tab and the SIV reading immediately starts reading.
