Morning,
Having massive issues after switching to new mobo.
Does anyone know what the light means next to the GDV pin on Gigabyte X870E? I can’t insert a pic sorry.
It’s either green or orange. It’s not mentioned in manual. Trying to fault find my system .
Story is:
Had to change to a new motherboard after a warranty item was no longer in stock.
Built the pc and no power. Been fault finding for 10 hours so any help appreciated.
Build:
Corsair 5000x QL case
Ryzen 7 7800X3D
Aorus X870e pro ice
7900XTX hellhound
Corsair RM 850 PSU
Corsair H150i cooler
DDR 5 Kingston fury RAM 2 x16GB
Actions so far:
- reseated motherboard,
- checked grounding motherboard
- disconnected and reconnected all cables including PSU
- tried without GFX fitted
- tried single module of each RAM stick
- PSU passed paperclip test
- tried powering / resetting from white buttons on motherboard.
- motherboard connected using two 8 pins.
- gfx connected with two separate cables.
- checked plug sockets etc.
What’s happening:
- absolutely nothing. No de bug codes on display, is an exclamation on AIO display. Possibly a small orange light but that stays on after power removed unless capacitors? Is green light when GGX installed. Definitely not the CPU/memory etc they are in a bank a separate light by the debug display. This is the only life on the mobo.
Any help appreciated.
Thanks.
Story is:
Build:
Ryzen 7 7800X3D
Aorus X870e pro ice
7900XTX hellhound
Corsair RM 850 PSU
Actions so far:
What’s happening:
Thanks.
