Gigabyte Aorus Xtreme Waterforce 2080 Ti - 2 pcie white leds
22 Mar 2017
Poland
Hello.
Gigabyte 2080 Ti Aorus Waterforce Xtreme
The LED lights are located above the PCIe power connectors on the card.
When card is underload i can see two white lights near pcie 2 connectors. Not blinking. Just white lights continuously. No problem in stability,clocks are normal.
Psu is Seasonic ULTRA TX 750W Platinum. Anybody have the same card?
Card is plugged by 2 separate pcie cables.
Anyone?
Your pic shows 2 solid white lights mean stable power, so all good
Or are you asking something else? Is it not working etc
Ruff night lol
Weird there are some peoples without that 2 white lights under load with the same card. And there are peoples with 2 white lights. But no issues still. Maybe its bios of card?
mine had two white lights I also thought there was something wrong with it they way the were always on.
So. The power led indicators light up for some reason and do not turn off until i restart pc. After restarting PC, they do not light up. At the same time, the logo stopts to play with colors, and burns constantly.
Even if I load the card heavily, the indicators do not turn on.
It happens sometimes on loading screen in 3dmark Port Royal. Also performance and clocks are not affected. Just that 2 constant power led white lights and gpu aorus logo stuck on 1 colour. In the same time ,card is not recognized Aorus Engine program in led settings.
When i reboot pc ,gpu logo is changing again colours and i dont see that power led pcie 2 white colours.
Can i ignore this??
Ok i resolved. I know why that happens sometimes in 3dmark loading screen time spy or port royal. because card is hitting power limit ( green on gpuz ) and then card pop up that 2 white lights. Nothing to worry about. I think its bios or something. anyway thx
