Hi all, had a frustrating day and just wanted to see if anyone out there has had a similar experience with this hardware.
Today my new Ryzen 3600 arrived. I am upgrading from a 3400g for the extra cores + I have a dedicated GPU now so the 3400g was a bit out of place with it's igraphics.
As per title I'm using a Gigabyte b450 board and it's running F50 firmware so should be ready for Ryzen 5 CPUs.
I installed it super easy, booted up and all looked good apart from my displays (connected to a GTX 1660 Super) - they flickered once or twice but seemed to stabilise. I went to run a user benchmark to check the new CPU was performing and then my PC black screened. It was as if the displays just shut off randomly.
Only thing to do was power cycle.. and alas the PC never recovered. Never saw anything other than a black screen until I put in my old CPU again. Tried reseating the RAM, resetting the CMOS etc. On power on all the fans spun up as usual but no signal was ever sent to the display.
Totally stumped. Anyone out there running a gigabyte b450 with a 3600? Is it a pipe dream? I'm no technician but the only explanation in my head is a faulty cpu? Or are these gigabyte boards just temperamental? Don't really wanna return the CPU if there is some way I can sort it.
