I have recently taken delivery of an X38 DS4, with a *groan* Q6600.
Setting it to run 333fsb is easy, but i found changing the voltages and RAM ratio an utter *******. I'd like to run it at 3.5Ghz, but have no idea what voltage to put it to, as Gigabyte don't actually display the voltage changes, instead they give you options for voltage increases, and the FSB
RAM ratio is nowhere to be seen =/ I've just got it, so it's the stock BIOS
