Gigabyte cpu cover?
18 Oct 2011
Just about to install a cpu into my friends motherboard, it didn't look like it had a cpu cover but when I put the cpu into the socket it seems the side closest to the ram slots is raised too high?
its a Gigabyte GA-970A-DS3P
yeah I dropped in the cpu with the leaver up? and then pushed it down when the cpu was in. I was just wondering cause the socket didn't have a cover on it.
It looks like its missing the cooler retention bracket, are you planning on using the stock cooler or an after market cooler? Other than that it looks fine
edit: actually just checked on the Gigabyte product page that looks exactly how its supposed to
Yeah, we're using the stock cooler. It didn't look like it had a cover on the socket, and when we put the cpu in, it didn't look like it was sitting properly - some of the pins on the side were exposed.
yeah we've got the golden corner matched up to the arrow on the motherboard. However the cpu is rocking as if its not sitting properly.
Its really wierd, we've double checked and it seems that nothing is wrong with the pins. The golden arrow is matching the one on the motherboard.
