- 22 Apr 2006
Hi there
My PC has recently devloped a problem with booting. The PC starts and all the fans run but it does not go into BIOS, so it just stays blank.
After Reseting the CMOS it goes back to booting normally, but quickly resets again normally before windows is even loaded, going back the the orignal problem.
The problem has grown worse over time. It first did it when I overclocked the CPU to 2.8 GHZ (400mhz), and was sometimes was stable for a day or so, so I lowered the clock speed and it carried on with the same probelm. It did it on stock speed as well, and eventually it just started reseting immiediatly on boot.
Before this the PC was stable on stock for monthes, and stable on 2.8GHZ for at least a month with no signs of any problems.
I think it's my Mobo that must be faulty, as I've heard of similar problems with the DS3, especially Rev 1. I've tested the RAM in other PCs and overheating of the CPU was never a problem with my Tuniq Tower. Is there anything else I should do or test before I RMA it, or could it be another problem such as the Power Supply?
My System Specs
E6300 w/ Tuniq Tower
Gigabyte DS3
Geil Ultra low latency RAM 2GB 4-4-4-12
X1900XT
Enermax 500W PSU
Seagate 7200.10 250GB
Thanks a lot for any help
Steve Mackie
My System Specs
Gigabyte DS3
X1900XT
Enermax 500W PSU
Steve Mackie
