Gigabyte DS3 Cycl Reboot - or Me Too
Was going to put this in the Gigabyte Guide but its too long I think.
EDIT: Note the actual mobo is a DS3, not DS3P like the subject said, my bad, but I think it makes little difference the exact version of GA965P.
So, add my name to the list of people experiencing cycle boot. Starts, no post, no fan spinning or beeps then shuts down at which point the fan suddenly starts spinning for a second. Repeat in loop. In fact my testing shows that it behaves exactly the same if the fan is unplugged. This before any overclock.
However, I had it working perfectly, no problems, proving my system did work. I had installed everything, playing games all running flawlessly except for a noisy fan. So I went into bios and set the smart fan control method to Intel QST. Saved changes and since then I've had cycle boot.
I've tried everything I can possibly think of with no luck. In no particular order:
1. Putting my 2GB 800MHz of Geil in DDRII1 and DDRII2 like the manual says
2. Using the red slots
3. Using older working Geil 667 MHz from another PC
4. Unplugging everything except ram, 1 HD and graphic card
5. Lifting up motherboard to ensure case not short circuiting it
6. Putting a jumper on CLEAR_CMS _and_ taking out the battery for over an hour. Yes, I unplugged powercord
7. Rechecking all cables.
8. Checking if fan is properly seated (question: Can poor contact cause my problem, as I've used only the out-of-the-box fan with no additional contact gel?)
Guess I'm gonna have to RMA it unless anyone has any further ideas?
System basics:
GeIL 2GB PC6400C4 800MHz Ultra Low Latency DDR2 Dual
Gigabyte GA_965P_DS3P (Socket 775) PCI-Express DDR2
"LGA775 Conroe" 1.86GHz (1066FSB) - Retail
Hiper HPU-4M580 Type R 580W ATX2.2 PSU - Black
All from overclockers...
Cheers
System basics:
Cheers
