- 3 Oct 2007
Hi
I bought a bunch of kit this week from OCUK to spec up, and have just finished building it. My issue is this - the Giga DS3R mobo had only one retaining pin in the northbridge heatsink instead of two, you know the white spring-loaded pins that keep the HS on and in firm contact with the chip. I solved it by taking one of the pins off of the chipset cooler on my old mobo, but the heatsink is still very loose on the northbridge chip - it wriggles around freely if I try to move it.
I have 2 questions - is it normal for the northbridge HS to be so loosely attached? The retaining pin I've used seems identical to the one that was on there. And what is a normal northbridge temp reading at idle? I seem to be getting 26C cpu (E6750) and 40C northbridge right now which feels a bit high to me.
Thoughts please? I really don't want to have to strip this all down again and return the mobo...
Thanks
Bert
Thanks
Bert
.. Not happy.. It's built now
