hi
im planning to get the following
C2D e6300 OEM
GeIL 2GB PC6400 800MHz Ultra Low Latency
AND Gigabyte DS4 or DQ6
i going to overclock the cpu to at least 2.5 ish
the only problem i have is choosing the mobo, the most important thing is overclocking features, is there any difference for overclocking between DS4 and DQ6?
I already know DQ6 has the following advantages over DS4
1) has a 12 phase power design instead of 8(so?)
2) Everything is Quad (whats the point??? e.g quad bios, quad sataII,quad bla bla bla)
3) crazycool thingy (i use watercooling, so it needs to be taken off)
4) better onborad sound (i wont use it as i have audigy )
considering DQ6 is £24 more expensive which one should i get??
thanks
C2D e6300 OEM
thanks
