Gigabyte DS4 rev 1.0
23 Nov 2005
Kingdom Of Fife
Guys,
My system is stable, prime torture test for 24Hrs (blend). I am though, a wee bit concerned about my system temps!, mainly the mobo!. After a few hours of gaming, I have noticed the reported mobo temps to be 52oC (Everest Engineer Edition), my CPU is at 43oc cores 1 and 2 (when the game is running) rest in the mid thirties, my GPU is at 72oC which is to be expected for a GTX OC2! I am pretty sure I have suffient cooling, a Stacker 830 with one intake at the front, three on the side, air outtakes at the back, PSU fan and 120mm fan also slot cooler between NB and GTX, Are theese temps OK? Room temp is about 25oC, the wife likes the heating on! Do you think another 120mm fan is required at the front? I also have an outtake on the top of the case.
Thanks in advance,
Jonnygrunge.
