Gigabyte EasyTune
Status
Not open for further replies.
16 Oct 2015
Norfolk, ENG
Evening people,
I was looking at my motherboard on the gigabyte website and stumbled across the Easy Tune description and what it does.
So it overclocks your CPU and you can choose from 3 different settings.
I have been thinking about overclocking my i7 5820k but I just don't feel experienced enough to do so and I am wondering if anyone has every used this program for setting up and overclock on the CPU? or even if someone has done it on the exact same CPU as myself?
What was your experience of it and did it even work for you?
Thank you in advance.
Alex
Didn't like it, you don't need experience to OC just patience and time and lots of reading, in essence all you do is find out what the max volts are, get a decent cooler and up the multiplier, then stress test. Does it crash? Yes, up the volts, No? up the multiplier, rinse and repeat.
Status
