Gigabyte EP45-DS4 hanging problem
26 Oct 2008
I have a Gigabyte EP45-DS4 mobo, and it keeps freezing randomly, no pattern to it, sometimes couple of times a day, sometimes once a week. Has 4 GB of Crucial ballistix memory, and a Q6600 cpu, running Vista x64, default mobo settings. Is any body else experiencing the same, or similar symptoms and has anybody come up with a cure?
I had a similar problem on my DS5 till i updated the bios i am now using the f6 one in mine and it hasn't had a problem since. I know some of the bios updates have been about better ram compatability so maybe you need to have a look and see if your ram is fully supported by the bios you have now.
Is the memory 4x1gb or 2x2gb?
If it's the former then adding 0.1v to the northbridge/MCH voltage can help.
