Gigabyte EX58-UD5 Question
What version ram did you get? I'm trying to find a second set of ver 3.2 to match the set I'm currently using with my UD5.
It's definitely compatible.
Not so helpful but thanks for the thought. It has a version number written on it, and I can't get a store to tell me what version they have in stock. Mine has v3.2 written on all of the modules, I'd be grateful if you could check which version they sent you as it will reflect what batch they currently have in stock.
