Gigabyte Fan Issue
29 Jun 2012
doesnt matter what i try on the mobo and settings i cant alter the speed of the case fans. ive got the coldest case in the world!
Z77 D3H
processor is at 34 degrees (been on for 48 hours!)
GPU is at 37 degrees
figures from CPUID HW
Fans only show on Fans not FANS PWM
Hi there
Don't think you can adjust the fan speed if they are plugged onto the motherboard they run at full speed.
Either put them on a fan controller or swap them out for pwm fans & get a pwm fan splitter them the motherboard will control the speed of them for you.
Got the same board as you & I am running my case fans off the built in controller on the Fractal R4 & my cpu cooling fans off the mb on pwm.
Cheers :)
