im using:Gigabyte GA-965P-DS3(F5_bios)...Intel Core 2 Duo E6400...Stock Intel cooler...2GB Corsair DDR2 XMS2-6400C5 TwinX...7900 GTO...
...Antec True power 550wPSU...Windows XP-sp2...
i have overclocked my processor to 2.60ghz (CPU Host Freq. 325mhz, memory multiplyer 2.50, memory running at 815mhz, at 5,5,5,12. PCI Express freq @100 )
I have set Fan speed control to LEGACY to keep noise down!
and the CPU is idling @ 51c (which im a bit worried about)
With fan set to full it idles @ 46-47c
firstly, i am checking temp thru bios, what is the best temp programme, (preferably a small inobtrusive prog.)so i can check temps under stress-load.
secondly, is there any way to reduce temp, (or is this temp 51c@idle quite safe for CPU) i have read you can lower voltage on these CPUs and they still run OK? (i would prefer to keep stock cooler rather than messing around fitting new cooler)
it is currently running very stable, in fact i have had it running stable at over 3.00ghz with same voltage, just higher CPU Host freq, but Temp is higher!
also is there any other bios tweaks i can make for overclocking, ie, voltage, memory settings etc
upto now all i have done is change CPU Host Freq,(@325mhz) PCI Express Freq,(@100mhz) system memory multiplyer(@2.50), memory timings (@5,5,5,12), and disabled throtling functions-CPU enhanced halt, CPU thermal monitor 2, CPU EIST function.
and GPU is running at (core 670mhz memory 1.45ghz=725mhz!)
cheers
cheers
